Question Anyone identify this engine serial?
Just got a 914, price was TO good, Not sure if the engine is a porsche or bus. I believe it's "W0052645." It's on the tranny side as a 1.7 should, but in the research I did do, it said the "w" was either a 914 1.7 or a vw 411 1.7. Any insight? Again, thanks for you time.
Old 09-16-2004, 03:37 PM
Banned
Alfred1's Avatar
My understanding is that the "Porsche" 1.7L motor from the 914 is essentially the same as the "VW" 1.7L motor. Check out this chart . You should be able to find your answer here .
Old 09-16-2004, 04:25 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
411 motors have the dipstick in the wrong location.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 09-19-2004, 08:33 AM
914 Geek
Sedans do but wagons don't. Or was it the other way around? Anyway, I believe that one of the two versions of the 411 has the dipstick in the "Bus" location, while the other has it in the 914 location.
Bottom line--the W-code motor is either the correct one for an early 914 (70-71), or it's close enough that you won't be able to tell the difference. (Or it has the oil filler and dipstick poking into the firewall of the 914--but I kinda doubt that's the case here. And even then, the performance should be the same.)
--DD
Old 09-19-2004, 12:25 PM
