-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Picture of Fuse box??? Help= (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/183590-picture-fuse-box-help.html)
adamd1514 09-20-2004 06:06 PM
Is their anyone out their who can pull their Fuse box down and take a picture of the back, i have a wire thats just chillin. Not connected to anything. If someone could get me a picture i could locate where it goes. I woudl really appreciate this. Thank you
elwood-914 09-20-2004 06:48 PM
Color of wire??:confused:
elwood-914 09-20-2004 06:49 PM
Oh yeah, what year?
adamd1514 09-20-2004 06:51 PM
1974
Its a black wire, just hanging off coming from somewhere near the middle (to the right looking forward)
Thansk for help
elwood-914 09-20-2004 07:00 PM
I see a black wire with a white stripe....... on my 73'
adamd1514 09-20-2004 07:26 PM
Hmm
Do you know where it goes to (ex. lights? )?
elwood-914 09-20-2004 07:37 PM
O.K. Took the fuse panel down. I have 2 black wires(no stripes), both are terminated to 1 connector and that connector is termated on the 4th terminal from the right, on the fuse panel.(sitting in the car) It is the terminal closest to the driver (closest side of fuse)
Hope this helps.
John Rogers 09-20-2004 09:56 PM
Probably it is/was for something that is no longer used or is not working? There are several switched 12 fused connections such as the one mentioned by elwood-914 which is used a lot. You might want to look up under the dash to see if there is a crimped ended wire that is just sitting there or one with tape on one end? Also is there any tape residue or solder on the end of the wire that is hanging as that can give you a clue as to what it connected to under the dash. Good luck
jamcleod 09-21-2004 06:14 AM
my recommendation is to compare your connections to the schematic. somewhere on one of the BBS's, maybe this one, there is a color schematic. with a 30+ year old car, you never know what the PO (s) did and it would be worthwhile to verify wiring connections....
oh...
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
adamd1514 09-21-2004 09:29 AM
When i get home ill try to check out where the wire is coming from and try some suggestions. Thanks for the replies
