cruiksdr's Avatar
Wiring help, please
I just got a newer tach (I think it's a 71 or 72). It has a 5 (or 6) prong outlet on the back where my old one had 3. Any help on on the wiring (eg, which prong is for what) would be greatly appreciated.
'73 914-6 3.0SC
'69 Jaguar XKE
'05 Colorado Crew Cab
Old 09-25-2004, 07:01 PM
ruddyboys's Avatar
Are you sure the Tach is form a 914? I have an early and late model and they both have only 3 connectors. It should be from right to left looking from the back, connector # 1 black/purple or black/red and goes to coil thru the relay box in the engine compartment. The center connector #15 red/white is power which connects to multi guage and finally to fuse #9. The last connector #31 brown is a ground wire. Hope this helps
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-26-2004, 03:16 PM
cruiksdr's Avatar
To clarify, this is a tach from a 911 for my six conversion. Here's a pic of the back.
'73 914-6 3.0SC
'69 Jaguar XKE
Old 09-26-2004, 04:55 PM
ruddyboys's Avatar
I think the best thing to do is go to the 911 BBS. They probably can tell you a lot more about your Tach, good luck.
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-27-2004, 06:37 AM
