Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
fiberglass flares
What is the best way of installing fiberglass fender flares. I do not have the funds for metal ones and this is my only option according to the "wife".
Old 06-12-2000, 05:39 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Send a message via ICQ to oredith Send a message via Yahoo to oredith
I'm on the brink of doing this myself, and this is the most comprehensive instruction i've received originating from Ed Villela. http://members.rennlist.com/evill/
(Tom, Wayne, DD, or Don, you guys there?.. might want to ask Ed if he wants to write an official copy for the tech articles)
anyways, here it is..
>First thing to do is to cleann the flares and fender with a good wax and
>grease remover. Then wash with warm soapy water. Now fit the flares to the
>correct fenders. It helps to have an extra set of hands here. Hold the
>flare tightly to the fender and check for fit .Adjust it so that it is even
>on both sides of the wheel well opening. Now take an 1/8-in drill and drill
>a hole in the top center of the flare, approximately 1/4-in in from the
>outer edge. Now insert a self tapping sheet metal srew in the hole. Do the
>same every 6 to 8-inches apart as you work your way out towards the bottoms
>of the fenders. I like to use the sheet metal screws with the hex heads,
>1/4-in I think. I use a cordless drill or a nut driver to insert these.
>Look for gaps between the body and the flare. Take a black marker and
>highlite the low areas, where you can see a gap in between the flare and
>the body. High lite the whole low area. Do this to all the low areas.
>Remove the flare and take a sanding block with 80 grit sandparper and
>slowly remove material on both side of the low area, then re fit the flare
>to the fender and check the gaps. If the gaps are less than a 1/16th of an
>inch you can stop, thats close enough. You want the flare to fit as
>tightly to the body as possible.
>Now take a scribe and outline the edge of the flare into paint on the
>fender. Remove the flare. Now follow the inside edge of the scribe with a
>strip of 3/4-in masking tape. Now follow the inside edge of the masking
>tape with another strip of 3/4-in masking tape. This will give you a 1 1/2
>-in border inside the scribe mark. This will be your cut line. The 1 1/2-in
>border will be used as your bonding area. You may need to trim this area
>down to a 1-in border.
>You can cut the fender out with a jig saw with a metal blade or metal
>nibblers. Follow the edge of the tape. Once the cut is completed, take a
>grinder and remove all of the paint in and around the bonding area. Clean
>bare metal is important here. Also grind the back side of the flare to
>rough up the surface. This will ensure a good bond with the fiberglass
>resin. Re-fit the flare. Look on the inside of the wheel well, is the
>metal sitting flush against the back of the flare? If not push or tap it up
>with a hammer until it is as close as it can get to the back of the flare.
>Next drill holes in between the existing srews , all the screws holes
>should be approximately 1 to 1 1/2 inches apart. The entire outer edge of
>the flare should have screws holes in it. Now remove the flare.
>Okay, we're ready to bond the flare on. Use Fiberglass Jelly Resin for
>this. Mix the fiberglass jelly and spread it onto the back edge of the
>flare. Put on a liberal coat, do the same to the fenders edge. You need to
>work quickly, you want to get the flare fit before the resin starts to set
>up. Now put your screws back in and put screws into the new holes that you
>drilled. A cordless drill with a nut driver works well for this. Screw the
>flare down tightly. Wipe away excess fiberglass resin. Let this set up and
>dry at least 24 hrs.
>When the resin is good and dry, remove the screws. Take a grinder and grind
>down the edge of the flare, blending it into the metal. Also grind down the
>area where the screw holes are.
>Spread a coat of fiberglass reinforced filler over the screw holes and seam
>where the flare meets the body. Press the filler into the metal and the
>flare to ensure a good bond. Let this dry and then cut it down slightly
>with a cheese grater. Now apply a coat of regular body filler over this and
>blend it into the body. It helps to use curved sanding blocks here. I use
>wooden dowels of various diameters wrapped with sand paper to cut and shape
>the inside curve areas.
>Fill and sand until all the curves feel smooth and flat.
>Prime with a good filling primer, block sand smooth and then paint body
>color.
>If these steps are followed correctly, the flares will be very rigid and
>will not crack and separate from the body.
Old 06-12-2000, 07:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Whatever you do, don't just pop rivet them on. I saw a 914 in Portland, OR two weeks ago where they did this. Nice neat job, but ugh!
Old 06-13-2000, 09:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
JTB JTB is offline
When the flares were put on my car, the body guy doing the work added one more step. After bolting them on with the sheet metal screws, he put a heat lamp near the flares for maybe a half hour. This caused the flares to relax a bit. He said that if you skip this step, the flares can heat up in the sun and relax, making it look like you didn't spend enough time on the fit and finish. I was there when he did this and could not believe hou much they moved. After that initial heat cycle, they took a set. He put the heat lamp up to them again to show me that they would not move after the intial heat cycle.
Old 06-13-2000, 07:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
good to know about the heat lamp.. thanks for the info.. now i just have to wait for my slow-a$$ roommate to get his supra out of the garage so i can work on my car..
Jeff
Old 06-13-2000, 07:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Thank you guys very much.Maybe this is something that needs to be documented for later review?
Old 06-14-2000, 06:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
