Jim Smolka's Avatar
GPM of an oil cooler for 3.0
Any one know the GPM for requirements for a 3.0 SC engine.
Also, I must run two coolers, so should they be in series or parallel...
Oh, any luck using Tru Cool coolers??
Old 06-16-2000, 03:25 AM
RETIRED
Joe Bob's Avatar
Why would you run two coolers? I use the 930 cooler with fan combo in my trunk....it works well in combo with the stock oil cooler on the engine....is that count as two?
Old 06-16-2000, 07:09 AM
Jim Smolka's Avatar
The reason for 2 tru cool oil coolers is that I am going to mount them behind the rubber bumbers of my '75 (my preference). I am going to cut the frame of the bumber in two places & the biggest cooler I can use is a 24 row cooler about 11" x 5"x 1.5".
I just not sure to run them in parallel or series. Any one used Tru Cool before?
Thanks...
Old 06-16-2000, 06:37 PM
What ever you decide, make sure:
1) the cooler should have at least 12AN hose fittings and hoses.
2) Use a top quality cooler. Earls, for instance.
3) Use an external thermostat of high quality. Troutmans has a good one.
This stuff ain't cheap, but neither is a blown motor. I've never heard of the cooler you mentioned. That doesn't mean it's no good, just an unknown.The Racers Group is a good bunch to find waht you need.
I'm going to need a cooler to go with the 2.7L I'm building. I figure about $1K for the goodies.
JPIII
Old 06-17-2000, 09:46 PM
