-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Cooling without the thermostat (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/187453-cooling-without-thermostat.html)
Aspi914 10-16-2004 04:24 AM
Just wondering if anyone has had any experience in removing the flaps that regulate airflow over the engine to allow max air flow all of the time. Do you need to keep the flap over the oil cooler in placed and should this be in the down position or locked half'n'half.
synthesis 10-16-2004 05:04 AM
screw the flap down.http://forums.pelicanparts.com/uploa...1097928240.jpg
SteveStromberg 10-16-2004 08:43 AM
Also make sure that the oilcooler air seal is in place.
hardflex 10-16-2004 05:37 PM
so it you screw down the oil cooler flap, do you leave the crossbar flaps piece completely out then?
SteveStromberg 10-16-2004 06:45 PM
If you have screwed it down there is no need for the crossbar.
Dave at Pelican Parts 10-18-2004 12:25 PM
It is better, IMHO, to leave the thermostat system hooked up and working. As long as you can get it working correctly. It's a Good Thing to get the engine up to operating temperature quickly.
--DD
