LinkBack | Thread Tools | Rate Thread |
Hot Coil
Author of "101 Projects"
If your coil is very hot, then most likely it is grounded somehow. When you are trying to fire the coil, it's not getting a good spark because there is a short somewhere. Check the connections to the coil, and make sure that the lead that attaches to the points is not accidentally grounded...
Hope this helps, Wayne |
Wayne,
Thanks for the advice. But I think I found the problem a burnt external coil resistor. I replaced the coil with a new one with enternal resistor and it tries to start more than ever but won't make it. Well time to dive into the fuel injection I guess. |
Thread Tools | |
Rate This Thread | |
