Lifting the inside wheel
Many 914s tend to lift the inside rear wheel when auto-xing and mine did this too. The rear sway bar and a 22mm front sway bar are now keeping the rear level, but it is lifting the inside FRONT wheel like some 911s! It has 22mm front torsion bars and 180# rear springs and I am wondering if 300# rear springs would cure this. At the Parade I have a great picture with the wheel in the air! Has anyone had this problem and solved it? The 914 GT's seem to be really flat through the corners at the same speed I run?
RETIRED
The book says no rear sway bar ubless you have an LSD.....I do, but don't run a rear sway bar either. I run flat.
I'll try it next month with and without the rear bar. I do have a Quaife and it tends to pull the car down when it is rolling.
