CHT readings vs EGT readings as indicator of Engine efficency
OK here's the background.
I am lucky to work alongside a seat of the pants hands-on mechanical genius. His reusme includes FAA certified aircraft powerplant mechanic since 1970, a Degree in Aeronautical Engineering , and currently as an Engineer emeritus he manages the "skunk works" for the largest aircraft fleet out side of the military . He holds patents on a number of tools and devices and is always ready to talk and teach on a variety of subjects. He has a pretty extensive hands on understanding of aircooled engines from aviation to harleys to old vws. So I asked him about the viablity of using cylinder head temperature as the primary indictor of engine health. His opnion was that CHT is adequate , but felt that exhaust tempature provides a better, faster feedback. He recomended installing two EGT sensors into the exhaust flow , one for each bank of cylinders. He then mentioned that you don't really expect them to match but you work with the carb mixture settings ( assuming close to correct timing) to determine the maximum possible exhaust tempature for each tailpipe. You then lean the mixture back so that your full load exhaust readings are 50 degrees cooler then maximum. After this inital calibration /tuning he claims that any changes in Engine efficency would be imediately apparent in the exhaust tempatures and that potential heat problems would be noted significantly faster then with a CHT based gauge. So my question for you eperienced engine builders and tuners out there is this : Do any of you have any experience with comparing CHT readings with EGT readings? Does the idea of an EGT gauge as a primary indicator of engine efficency make sense? If not why? I look forward to hearing some informed opnions Bill |
914 Geek
From my readings, CHT is not used as an indicator of engine efficiency. It is used as an indicator of, "OH CRAP!!! My engine is melting down!"
EGT, from my talks with a couple of racers, is a good indicator. However, you have to dyno first to find what EGT your engine makes its best power at. You do all your tuning for max power, and make a note of what the EGTs are. Then you can use your EGT gauge to help you re-tune that particular engine when conditions change (e.g., air temps or humidity are different). I am not expert or even that well informed on this subject, but the main guy I was talking to about this built and ran a 200+ HP 2.0 914 motor in his race car. (It broke every other time he ran it, but boy was it fast!!!) --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
My Dad did this in the 80s and really makes tuning carbs easy. The readings you get are real time and it works great.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
A CHT and EGT set of quad gauges can transform your car into a rolling dyno of sorts for tuning..
EGT is most definately a tool for measuring efficiency for us..
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
Any sugestions for where to get parts to do this sort of thing?
Who make the best setup? and then what is the best DIY setup? Also anyone out there done this sort of thing and then added FI.. I am thinking megasquirt etc.. as a possible winter project. So any one who has gone the DIY FI route have any suggestions on what worked well? or what did not. |
Banned
I just got a new book and this is what it says
Of course.........
Banned
Seems that you are pretty good at that yourself...
Banned
Do your dyno tests show that the lowest BSFC numbers are obtained when the mixture is slightly lean and when the exhaust gas temperature is near its maximum? I'm no expert but that's what the book seems to be saying at least for certain operating conditions. I know you said that you hate the stock cam because all of the heat that it produces indicates a lack of efficiency.
enthalpy? We don't need no stinkin' entthalpy!
Cuurent fleet: 76 914 2.0 with subtle tweeks ..my grin machine 66 Black Ghia..all original ,including rust 66 Red &White Ghia 2liter 914 engine ..restoring it from a californicated custom soon 90 Maroon and Silver Conversion Van ..the shag mobile..family car/camper 94 saturn wagon ..the wifes pos |
