3 stud intake 2.0 heads
Hi, I'm new here. here is my question;
I have a 73 2L 914. Saved her from the junkyard, and built a Baja type 914, for rallye purpose through Baja.
Dropped a valve seat on #1 exhaust valve (think it's a dropped seat recessed into the head about 1/4") didn't break it, or damge the piston........drove it home from mexicali, and pulled the engine...
It was popping out the exhaust....#1 exhaust valve was way tight......reset, and the valve got tight again in about 500 miles....twice....
Pulled eng/trans, pulled the heads off......3 stud intake, oval exhaust ports......but, I have the deep dish pistons...1/4 inch or so deep.
My question, is about repairing replacing the heads........I didn't have enough compression before for any power (cuz the deep dish pistons) I'm thinking about replacing the heads with Bus heads.......I hear they have different head chambers, for the deep dish pistons........3 stud 2L heads were for flat top, or domed pistons....higher compression pistons.....
I'm thinking about the 021-101-371S heads..... to compensate for the deep dish pistons......for my economical top end rebuild.
Any advice on a good set of heads parts # that mate with the deep dish pistons would be appreciated....... this is the first time I have had a 914 engine out of the car.....and my first time posting here.........
Old 12-06-2004, 01:58 PM
Banned
Alfred1's Avatar
Len Hoffman could probably answer all of your questions.
Old 12-06-2004, 02:02 PM
Thanks Alfred, maybe I'll try to contact Len Hoffman, or see if he responds....
Once again, many thanks
Old 12-06-2004, 02:08 PM
Banned
Alfred1's Avatar
You're welcome. Len is also pretty active on the Type 4rum so you might ask there as well http://www.shoptalkforums.com/viewforum.php?f=1&sid=5f173f4d38f68e136ec0f7fe9109f652 .
Old 12-06-2004, 02:23 PM
Thanks again Alfred.
I'm still trying to get used to this board, and clicking links provided.....but, it's not going well!
Do you have a simple website for the T4rum, where info, from Len Hoffman and others may be helpful......
Sorry my computer isn't cooperating with clicking links today.
Old 12-06-2004, 02:40 PM
Alfred... I found it on search...I was trying T4rum, and you said Type 4rum....
My mistake. thanks for the lead.
Old 12-06-2004, 02:46 PM
Don't get rid of those heads! They are cherry base heads for a bigger engine. Len can repair them and you'll never know they were previously damaged.
Bump that baby up to a 96mm bore to make a 2056, have Len repair that head and then get a nice camshaft to compliment the heads.
You have a private message...
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 12-06-2004, 03:12 PM
thanks for the info Jake, some others have also told me the same combo as you..........but for this engine, I want a good torque engine, I'm not as concerned about a high rever.
But I want to have these heads rebuilt for a future motor, with the 96's,........ what kind of cam would you recommend.... I like torque, cuz I'm off road alot. and with taller tires, I need the torque.
I'm new here, can someone tell me how the private message works?
Old 12-06-2004, 03:32 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Can't say a 67hp bus motor is a good torque motor vs a 2056cc 110hp/120lbs torque motor. The bus pistons were for low compression so why would you go to a low hp set up for a baja?
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 12-06-2004, 05:22 PM
You will also gain torque with the bigger bore and the right camshaft.
I do this everyday- All day, listen or you are going to have all sorts of issues.
The small valves in the bus heads may be great for port velocity, but they SUCK for chamber filling! Chamber filling at the desired RPM is the key to big, flat torque while retaining good running temps.
The cam I would set you up with is split lift and duration and has an AWESOME flat torque curve with stock ported 2.0/914 heads.
Jake Raby
Old 12-07-2004, 06:22 AM
