Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Reichart Flat Fan
I thought some of you would like to see one close up.
Old 12-16-2004, 10:44 AM
Conrad W Peden's Avatar
Geez, been a while since I've seen one of those!
Any detail pics on the cooling tin?
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 12-16-2004, 10:50 AM
Banned
Sure what do you want to see?
Old 12-16-2004, 11:09 AM
OCD project capitan
BigD9146gt's Avatar
Now thats the *****!!! I would love to get some drawings on the 935 type fan and make some kits.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 12-16-2004, 11:53 AM
BURN-BROS's Avatar
Thats the same set-up for the corvair. They had a tendancy to throw the belt. Do these have the same problem? Looks pretty cool b.t.w.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
1071 Avenida Acaso suite D Camarillo, Ca.805-240-6931
https://www.instagram.com/burnhamperformance/
Old 12-16-2004, 12:01 PM
Banned
I will get you som close ups. it is a very simple mount. The fan spins on a spindle.
Just let me know what you want to see.
Old 12-16-2004, 12:36 PM
Banned
Old 12-16-2004, 12:44 PM
Banned
I am setting up the linkage for the carbs.
there is a little bit of play in it.
This is not good. This will need to be taken out to get it to run proper.
The Arm and the linkage rod heim bolt are way too sloppy.
A bushing is called for to remove the play.
No problem an old Base shim.010 should work.
Old 12-16-2004, 12:51 PM
Banned
Tighten it up and it as soild as a rock no more slop.
Now let get rid of the slop at the pivot point. Coke can provides the shim stock.
Now it's ready no more slop. Now to repeat on the other side.
Old 12-16-2004, 12:57 PM
grind weld build
sean_V8_914's Avatar
917 style, I like it. I wonder if RAT has any test data on that. I noticed that he is usign a 5 blade fan. Is 11 too much air? Corvair's late style fan pushes less air than teh earlier style vair
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 12-16-2004, 01:27 PM
Thats what I had in mind, thanks Steve
Old 12-16-2004, 03:58 PM
mike95125's Avatar
The Vair belt problem is easily rectified. I still don't like the horizontal fan thing, though. Looks wierd unless there is 8 cyl under it (now that is sexy).
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 12-16-2004, 04:36 PM
Racer Chris's Avatar
Here is a pic of my corvair fan setup on my FP race engine.
It works really well btw, no problems with belt loss.
Chris Foley
CFR-Tangerine Racing Products, LLC - 914 Products and Services
Old 12-16-2004, 05:13 PM
Porsche Doc's Avatar
Here is one that I designed about 10 years ago.
It's electric. I have been selling for years.
Thanks!
Don Ramsay
AirCooledClassics.co
Check us out on Facebook and give us a Like --> www.facebook.com/AirCooledClassicsPorsche/info#!/AirCooledClassicsPorsche
Old 12-16-2004, 09:15 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Looks just as Mickey Mouse as the setup on the Corvair... Not sure if a five blade fan is going to provide adequate cooling for th Type 4...
Old 12-16-2004, 09:29 PM
Acox914's Avatar
Send a message via AIM to Acox914
wrong! the 11 blade fans use TOO much air!
go over to 914club.com i posted asking if tests had been done on the riechert fan vs 911 shrouds vs stock vs DTM
see for yourself....
-Aaron
"60% of the time, it works every time"
Old 12-16-2004, 10:35 PM
Scooter311's Avatar
Total noob questions here sorry - -
Can you change the top fan pulley to alter the fan volume?
Also, what difference is there between this and the 911 upright style? It would look to me that junk could get in and make a mess easily. Prolly just for racing right?
(Hey Jared my dad used to use that expression all the time, haven't heard it in ten years, funny!)
- "NOW" Magically Delicious -
Old 12-17-2004, 05:58 AM
Acox914's Avatar
the 911 fans and the richert fans do not support stock oil coolers. you have to run an external cooler.
like i said, there was a BIG thread on the other board about all these specific questions...
-Aaron
Old 12-17-2004, 07:25 AM
OCD project capitan
BigD9146gt's Avatar
Acox, in which way do they not support stock oil coolers? All 911 engines (up to 89 at least) have an oil cooler on the motor and it works with that?
Don Welch
Old 12-17-2004, 07:51 AM
jhadler's Avatar
Can you post a link to that thread?
-Josh2
Old 12-17-2004, 09:20 AM
