-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Engine rotation direction (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/197520-engine-rotation-direction.html)
kdfoust 12-19-2004 10:26 AM
So I monkeying around with short block on the engine stand and trying to remember which way the engine rotates....
I'm thinking that if you're standing facing the flywheel end of the engine (back of the car if the engine was installed) the engine would turn counter clockwise. Is that right?
TIA,
Kevin
Dave at Pelican Parts 12-19-2004 02:28 PM
I believe so. Look at the fan blades. There is a convex side and a concave side to them. The blades should "scoop" the air with the concave side.
--DD
Jason Porter 12-20-2004 06:15 AM
Looking at the flywheel, the engine does turn counter-clockwise during normal operation...
kdfoust 12-20-2004 09:00 AM
Excellent! We have a consensus. Thanks gentlemen.
schosh 12-20-2004 12:20 PM
So it must turn clockwise below the equator........
LakeCleElum 03-14-2011 10:35 AM
Easier to remember if engine is in car (maybe adjusting valves). Clockwise if facing the fan!
