Rear brake disk fit
I was installing a rear brake disk and have a fitment issue. When I put the disk on, the 2 attachment screws will go in but it pulls up uneven. It appears that the hub catches on the inner lip inside the disk.
Has anyone had this problem before? It looks like I need to put the disk on a lathe and trim the lip inside.
Old 12-19-2004, 06:32 PM
SGB SGB is offline
SGB's Avatar
When i did my rear rotors, it pushed on with no problem. What brand of rotors are they?
-Scott
My gallery page
Old 12-20-2004, 06:44 AM
OCD project capitan
BigD9146gt's Avatar
Hammer. Or, bolt the wheel up, tighten it down, then unbolt the wheel. Sometimes its just a tight fit to the rear rotor.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 12-20-2004, 09:16 AM
Text me.828-230-0788
Joe Bob's Avatar
Standard four lug should be no problem....do as suggested above.
if you have changed to five lug and are using 914/6 rotors with /4 calipers....that is common. You need clearance the caliper a bit....
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 12-22-2004, 02:08 PM
