MSD on 2.0 914?
hi
we have a 912e (okay 914 2.0 in 911 drag- kidding!) with the oem injection. upon installing the msd 6a and blaster coil, the injection and tach leads go to the coil- the car fires but will not run. msd says that a tach adaptor is needed. Is this correct? what experiences have you had doing this type of install?
thanks
Old 12-28-2004, 04:23 PM
Acox914's Avatar
Send a message via AIM to Acox914
mallory says the same thing.
You need a tach/FI adapter
-Aaron
"60% of the time, it works every time"
Old 12-28-2004, 04:29 PM
reading other threads here- some ahve had the tach reworked for the msd signal- not hard- ho ho speedo is our neighbor. what about the f.i. signal? will it work off the pertronix output? or will it work off the tach adaptor if we go that route?
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
Old 12-28-2004, 04:59 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Dave, Just throw an Auto Meter tach in the car. Then no Tach adapter is needed. It can run right of the MSD box.
Why would the tach adapter effect how the car runs. That should only effect the operation of the tach. Unless the tach hooked up to the coil- is giving the FI a mixed signal or something.
If you disconnect the tach wire from the coil- does the car run OK?
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 12-30-2004, 09:02 AM
ok- here was the fix- msd diagram was not correct. there is a tach output connector on the 6a. from there it connect to the tach adaptor 8910. then to the stock tach/ F.I. connection. thereby keeping the originality of the client's 912E
1970 911 Spyder
1970 911S Conda
Old 12-30-2004, 09:03 AM
easy enough....
Sent you an email Dave..
Have a great New years.
Mark Scott
Vintage 911 Racer
Old 12-30-2004, 09:10 AM
happy new year to all!
1970 911 Spyder
1970 911S Conda
Old 12-30-2004, 10:27 AM
