Red face what special tool is needed to press off the gears on 914 crank?
Starting the rebuild of a 1975 914-2L spare engine. Got down to the crank and the stupid bearing is behind the intermediate (timing) gear driving the cam gear. Does anyone know how to remove the gears (brass distributor drive and steel timing gears) using a press (have a 20 ton press) but no collars to grip the timing gear while pressure is applied to the nose of the crankshaft. Does one cut off the bearing before the gears can be pressed out? What is the tool (part number and source for me to order one?
Old 01-03-2005, 11:50 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
I use a 3 leg puller.
Old 01-04-2005, 07:32 AM
I tried a 2 leg puller and it didn't grip well enough to work. Also I think the damn parts are rusted together over the years (30). Need to get the proper tool for the press to work.
Old 01-04-2005, 12:29 PM
Banned
Try one that looks like these.
Old 01-04-2005, 12:55 PM
Where do you get the bottom one and how much is the costs?
Old 01-04-2005, 01:11 PM
Never left, but not right
Zeke's Avatar
AutoZone.
Old 01-04-2005, 07:00 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Heat up the gear with a torch and use the puller to get it off. Be careful not to stracth the crank up. You can rent them at autozone for around $10 or so...
Old 01-05-2005, 07:17 AM
skline's Avatar
Or you could just buy one for about 19.00 at Autozone. I used a 3 prong puller purchased at Autozone for about 24.00. I still have it too. Use it all the time.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 01-06-2005, 08:34 PM
canna change law physics
red-beard's Avatar
You can buy a set of the pullers, 3 different sizes, for around $20 from harbor freight. I picked up both the 3 leg and 2 leg sets.
James
Red-beard for President, 2020
Old 01-07-2005, 02:54 AM
Thanks, my local Autozone didn't have the right size pullers. The gap between the bearing and steel gear is about 4.5 mm, most of the jaws of the pullers are too thick to get inside the back of the gear for a good grip. I am thinking of buying some steel sheets 0.017 inch thick hard alloy (4" wide by 8" long) and drilling a 60mm diameter hole through 2 pieces centered to make my own collar for the press to work.
Old 01-13-2005, 02:08 PM
Porsche Doc's Avatar
A Press collar !
Thanks!
Don Ramsay
AirCooledClassics.co
Check us out on Facebook and give us a Like --> www.facebook.com/AirCooledClassicsPorsche/info#!/AirCooledClassicsPorsche
Old 01-13-2005, 03:43 PM
Don,
that's what I've been asking all along.....does anyone know where I can buy a ready made press collar?
Old 01-14-2005, 12:12 PM
ws91420's Avatar
Send a message via AIM to ws91420 Send a message via Yahoo to ws91420
You can take it to shop that has a bearing press and remove it. To install use torch or oven method. Thats what I did.
76 914 2.0 (critical condition)
73 914 1.7 (new project)
04 Pontiac Aztek (parts hauler)
Old 01-15-2005, 05:20 AM
I found what I was looking for in link:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=3979
It's called a bearing separator and used with a press like I described.
Thanks for all the other answers.
Old 01-27-2005, 11:51 PM
