elwood-914's Avatar
Thermostat
Is the thermostat still an available item? I can't seem to find it on the P.P. on line catalog. If not is there a alternate replacement? Thanks
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 01-11-2005, 07:10 PM
I heard somewhere (Aircooled.net?) that you can use a Type I t-stat with some minor modifications. I believe he (Jake Raby) might also stock some OE Type IV t-stats, but that was awhile back.
Good luck!
Kevin
"Whether you think you can, or think you can't, you're probably right" - Henry Ford
'73 914
'75 914
Old 01-12-2005, 01:56 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
yup, they are NLA. However, and some may disagree with me in saying that they really arent needed for California's climate. However, I'd do what Jake says.. Besides, the flaps will automatically open without it anyway.
Old 01-12-2005, 07:32 AM
bd1308's Avatar
Send a message via AIM to bd1308
a couple thermistors, a BASIC stamp and a servo would make a very cool thermostat!!! very expensive though
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 01-16-2005, 12:53 PM
elwood-914's Avatar
That would be cool, but we teener owners are a bit on the cheap side aren't we......
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 01-16-2005, 01:27 PM
bd1308's Avatar
yeah....I have heard of people who just leave them off....the flaps stay open and it takes FoReVeR for it to warm up
Old 01-16-2005, 01:32 PM
elwood-914's Avatar
Somewhere in the archives, there is a picture of some of the guys screwing the flap closed.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 01-16-2005, 02:15 PM
bd1308's Avatar
http://www.thesamba.com/vw/classifieds/detail.php?id=123484
there we go man....for the 914 too! Check it out
Old 01-16-2005, 02:19 PM
bd1308's Avatar
don't the flaps control the air-flow to the engine??? to me, it would seem that screwing them CLOSED would destroy the engine, or at least make it overheat...
Old 01-16-2005, 02:26 PM
elwood-914's Avatar
I could see that in colder climates by leaving the flap open would warm up the engine fine but I believe it closes and directs the cooling air to the oil cooler. In warmer climates I could see them just closing the flap and making sure the oil cooler gets it's air.I will be putting one on mine but the climate isn't that bad in Calif. By the way thanks for the Samba info.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 01-16-2005, 02:46 PM
Scooter311's Avatar
Mine is shot, and I run it during the spring/summer/early fall with the flaps open. I just let it warm up for a minute or two longer than usual. I haven't had any trouble yet, but a new t-stat is on my "eventually" list
The design is such that if the cable or t-stat fails, the flaps flip into the best position for optimal cooling at all times (I don't remember which it is, 'open' or 'closed')
- "NOW" Magically Delicious -
Old 01-17-2005, 07:36 AM
elwood-914's Avatar
My engine is out right now and it looks as if the cable fails the flap would close and force the air over the oil cooler.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 01-17-2005, 10:56 AM
The flaps are spingloaded to the full open position in the case of a cable failure. If the t-stat fails it expands like the one in the pic from Samba, it's just like the engine is fully warmed, and the flaps go toward the open position.
'73 914
'75 914
Old 01-17-2005, 11:46 AM
bd1308's Avatar
it's spring loaded i know, but it would seem that having it default to closed would have a negative impact, unless just cooling the oil would be sufficient. I am confused, i guess i need a visual. It seems to me that if the t-stat failed that the flaps would open to cool the cylinders, or open to a both oil and cyl cooling mode?
Old 01-17-2005, 11:47 AM
bd1308's Avatar
i'm with special K on this one.
Old 01-17-2005, 11:49 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If the T-stat fails, the spring forces the flaps into the "open" position--as in, "cool the engine as much as possible". Take a look at how the flaps move, including the fiddly linkage bits on the right side. And also look at how the right-side flap works with the oil cooler, where the front edge of the flap winds up when the flaps are "open".
--DD
Old 01-17-2005, 05:26 PM
Scooter311's Avatar
Hey bd after you drop your engine to fix that cyl head you'll get a good look at how it works
Old 01-18-2005, 05:02 AM
