sway bars
How can you tell what size sway bars are? Mine are in a 74' 914 and they look stock.
Shawn |
measure the round part. they came in 15mm, 17mm, 19mm, 21mm. Stock is most likey 15mm.
there were early 911 13mm swaybars and a rare 76 turbo 18mm bars that are all interchangeable :) |
IIRC, a 914 stock front swaybar is 15mm and stock rear swaybar is 16mm.
--DD |
Thanks for the info guys.
Shawn |
Acox, i wasn't aware that they went down to 13mmm! wow!
Daves right, 15 front and 16 rear. You can tell by looking at the end of the sway bar, one side will have the size stamped on it, the other might have a letter or something else... But it does tell you. |
| All times are GMT -8. The time now is 08:32 PM. |
