Outacontrol's Avatar
Send a message via Yahoo to Outacontrol
EMPI wheels......VW?
Does anyone know if wheels from a 1968 type 1 vw have the same bolt pattern as a 1975 914?? I have a chance to get a great deal on a set of EMPI's. If not, maybe somewhere I can get some information on this? thanks for your help
Steve D.
75 1.8L L-jet
Old 01-14-2005, 08:54 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I believe (not sure!) that a 68 Bug would have a five-bolt pattern. Our 914 uses the four-bolt pattern which was also used by the later Bugs. Note that Bug wheels sit further out away from the center of the car than 914 wheels, so you stand a good chance of not being able to fit anything wider than a 165-width tire under stock fenders if you use a Bug wheel.
--DD
Old 01-14-2005, 08:58 PM
Thanks Dave..................the bug wheel is a 4 bolt pattern. I wonder what the offset is on the empi wheel.
Steve D.
75 1.8L L-jet
Old 01-14-2005, 09:14 PM
Send a message via AIM to John Kelly Send a message via Yahoo to John Kelly
Steve,
The bolt pattern is the same. They do fit a 914. You can pick up a set pretty cheaply these days. I've seen them go for as little as $80 in fair condition... about $180 a set is more typical.
John www.ghiaspecialties.com
Old 01-15-2005, 04:34 AM
Do you know if the offset on the empi is different than the stock 914? I am concerned about my limitations on tires.
thanks John
Steve D.
75 1.8L L-jet
Old 01-15-2005, 08:36 AM
type47fan's Avatar
EMPI style wheels on a 914
I have run them on all of my 914s during the past 30 years with no problems. Here is a picture of a genuine EMPI on the front of my '76 914. Good luck.
Wayne (type47fan)
Wayne Cowie (type47fan)
'66 VW 113 Rubin (Ruby Red)
'76 914 L31M (Scarlet Red)
'04 Toyota Sienna LE AWD
Old 01-15-2005, 08:47 AM
grind weld build
sean_V8_914's Avatar
I ran 195-50-15 BF Goodrich and 195-55-15 Sumitomo and Yokohama 205-50-15 HR03 . all on VW Empi that came off of my 70 Ghia. REAL EMPI wheels are 3 pc expensive and rare. The commonly available one pc are EMPI imitation. I had the more common imitations on my 914 and Ghia
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 01-15-2005, 11:12 AM
grind weld build
73 Orange, CS #601
Trek 6500+
Sean M!
Old 01-15-2005, 11:20 AM
I am currently running 195/65 on the stock rims. Hopefully they will work on the empi"s
Thanks everyone for all the feedback
Steve D.
75 1.8L L-jet
Old 01-15-2005, 11:23 AM
grind weld build
this 3/4 side view shows teh offset position into teh wheelwells. the rear was tight, less than 1/4 inch clearance
73 Orange, CS #601
Trek 6500+
Sean M!
Old 01-15-2005, 11:35 AM
what size tires are you running on the rear that only gives you a 1/4"?
Steve D.
75 1.8L L-jet
Old 01-15-2005, 04:01 PM
grind weld build
73 Orange, CS #601
Trek 6500+
Sean M!
Old 01-16-2005, 06:52 AM
grind weld build
Khumo Excta 712
73 Orange, CS #601
Trek 6500+
Sean M!
Old 01-16-2005, 07:15 AM
