-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   2.0l vs 2.0l Whats the difference (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/201822-2-0l-vs-2-0l-whats-difference.html)
Markeydoo 01-16-2005 02:08 PM
Ok what is the difference between a bus 2.0l and a Porsche 2.0l??
Also what is the largest relible size I can go to if I rebuild the Bus 2.0?
Mark
Alfred1 01-16-2005 02:16 PM
Should find your answers here http://www.tunacan.net/t4/reference/case.htm .
sean_V8_914 01-16-2005 06:57 PM
good link, thanks
Markeydoo 01-16-2005 07:43 PM
Thanks. Now I need to look at the numbers. What would be the largest I could build the bus motor??
Mark
Dave at Pelican Parts 01-16-2005 09:30 PM
3 liters plus. Bring money--cubic money.
You can build any displacement Type IV engine on any Type IV case. Some need a little more work for some applications (e.g., you have to block off the oil filler/dipstick hole in a Bus case to use it in a 914), but you can base your engine on just about any crankcase.
Going beyond ~74mm stroke requires quite a bit of work. Going beyond ~96mm bore can be done without a lot of work (and won't last), or with a lot of work (and will last a little bit) or a massive cash infusion for Nikasil-plated aluminum cylinders (and will probably last reasonably).
For a ton of info (and some propaganda), see http://www.aircooledtechnology.com .
--DD
Jared at Pelican Parts 01-18-2005 12:05 AM
Re: 2.0l vs 2.0l Whats the difference
Mark
Short answer?
Heads, Flywheel, Sheet Metal, Pistons, Valves, Crank are all different.
Basically, the case is the same... Except the dipstick is in a different location..
Bus 2.0L's wil need a lot of work to make them large and reliable..
Aircooledtechnology.com
Jake Raby is the Shonuff' of the Type 4
COLDBASS 01-20-2005 03:37 PM
Quick dicking around. You know that you want to go "six"...;)
Markeydoo 01-20-2005 09:27 PM
Your Right. You got one cheap?
SteveStromberg 01-21-2005 06:25 AM
Mark
Scott is pick up a 3.0 that he maybe selling.
I will be looking at it over the weekend .Its a fresh rebuild but its in peices but I will assemble it. Give him a call.
COLDBASS 01-21-2005 06:04 PM
As soon as the GF discovers that I have more than 2 Porsches, I will probably be "influenced" into selling something...either that or buying her that damn "Wolf" stove...too bad she doesnt know how to cook..:eek:
Why dont you hook up with L. Jones and buy his neighbors '70 or 71 (?)...I think that the gent grew tired of the project and wants to unload. I guess the the motor is pieces (4 cyl)...I thought he said $1k. Put a six that one...
Markeydoo 01-22-2005 11:04 AM
I'll check with them
Thanks Steve and Bob
