smooth_eddy's Avatar
Question Optima battery probs.
I bought a Optima 34 R last Fall. My car has been sitting for over 6 weeks in the garage due to the lousy weather here. Finally, today I got a chance to drive it and the battery was dead. After a jump, and it ran for a while the battery was fine. Is this normal? Also, the battery does not fit the tray flat. It rides up on the lip of the tray. I thought the 34 R was the proper battery for these cars?
1974 - 914----2056 FI
Old 02-01-2005, 06:19 PM
Six weeks is quite a while to go without a charge. Your radio or something else could be leaking a small current too.
Old 02-01-2005, 06:54 PM
Put a disconnect switch to your negitive side of the battery. turn it off when your not using the car regularly.
God Bless You and Your 914
Old 02-02-2005, 03:34 AM
A disconnect switch would have to be huge to handle the starting current. I am not sure that is a good solution.
Old 02-02-2005, 03:57 AM
brownaar's Avatar
Buy a Battery Tender or other trickle charger. They're great for these foul-weather/salt months. I think mine was like 15 or 20 bucks and it has a trickle charge as well as a more powerful charge if the voltage is lower. It had adapters to hookup clamps to the posts or more permanently with ring connectors to hook on the post clamp bolt.
Aaron
Aaron
1973 914 2.0, Bahia Red
Old 02-02-2005, 07:37 AM
OCD project capitan
BigD9146gt's Avatar
Eddy, the disconnect switch is heave enough, and it is a good solution for a number of reasons...
1) Great anti theft device
2)Purfect for doing electrial work on the car (simple twist and your no longer connected, as opposed to having to undo the clamp every time)
3)Some come with a small inline wire with fuse to keep a clock or radio's memory, but not enough to start the car with)
Another thing about the Optimas, is most chargers won;t charge them b/c of an internal regulater device. Sometimes you need to hook a regular acid battery up to the optima and charge the two in line... IE, acid battery (+) to Optima (+), acid battery (-) to Optima (-), charger to acid (-) and Optima (+) or either way. That tricks the charger to charge normally.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 02-02-2005, 08:49 AM
Don...
Not sure what you are talking about. Putting batteries in series (+ to - and - to +) will give you 24 volts. That will cause all kinds of problems. As for the disconnect, is there one made especially for cars?
Old 02-02-2005, 01:08 PM
OCD project capitan
BigD9146gt's Avatar
Eddy, your right, i changed the original post.
Couldn;t find one from our host, but this is it:
http://www.batteriesareus.com/shop/product_info.php?cPath=25&products_id=64&osCsid=dc09de7728bb169db08b02327374ecc0
Should be able to find one at a local auto parts store too.
Don Welch
Old 02-02-2005, 03:01 PM
Don... Thanks for the link on the disconnect. Looking at the photo I can see it is going to work fine for my needs. A picture is worth a thousand words. I like the idea of being able to disconnect the battery quickly when I need to work on the electrical system.
Old 02-02-2005, 06:21 PM
Eddy, for the Optima to sit flat on your battery tray, the bottom of the Optima has to be trimmed a little bit. You should take the battery to someone who has experience doing this.. don't get this done at a Costco-type place. I recommend taking it to Redmond European (Redmond) or Gerber Motorsports (Seattle), as those shops have the most 914 experience in this area. They are very honest, and they'd probably trim it for free if you bring donuts or talk about other stuff you need done. Once you have the battery out of the car, it'll only take them a minute or two to trim it.
Give them a call first, so they know to expect you. You really should meet these guys, and this is a perfect excuse to stop in and see them!
Old 02-03-2005, 01:29 AM
Be sure to use the disconnect on the ground or negitive post.
Old 02-03-2005, 05:25 AM
