1.7L Fuel Lines From tank
I was thinking if I had the return fuel line from the tank swapped with the supply fuel line. Is there a way to tell which ones which?
Old 05-04-2012, 10:47 AM
The supply line is the larger of the two. Do you still have the stock FI system?
Dave
Old 05-04-2012, 11:29 AM
Yeah its still stock
Old 05-04-2012, 11:31 AM
80-911SC's Avatar
I am not 100% sure on that .. if you have two different sizes the larger is the feed (9mm feed 7mm return) some of the years have both the same size ..I think if you go to the bottom and look at the lines the upper is the feed ..
Also another quick way is to disconnect both and bump the key to allow the fuel pump to cycle ..
the one that spits at you will be the feed ...
Steve ........
Dave did you get gas running thru yours yet ????
Old 05-04-2012, 06:33 PM
