SUSPENSION BUSHINGS
NEED INFORMATION ON HOW TO REMOVE THE REAR TRAILING ARMS TO REPLACE THE BUSHINGS.
My first word of advice, having learned the hard way, is don't plan on replacing them yourself. Here's what I did. The through bolt at the front of the arm is mounted at two points. I removed the inside nut and removed the three bolts that mount the outer bracket to the chasis. I also removed the rear brake caliper, undid the axle from the transmission and removed the bolt that mounts the shock absorber to the arm. Then I took the whole assembly (axle and arm)to a local shop that works on Porsches. They pressed out the bolt, installed my new bushings (which I provided, along with grease) and reinstalled the bolt. It only cost me $25 extra dollars for them to correct my poor self-attempts at installing the bushings. The normal bushing installation cost is $75 per arm, I bring in the arm and bushings. It's well worth it given the aggravation I had been through trying to do it myself.
Thanks Steve, I will take your advise. After talking with other 914 owners they all gave me the same advice. Again thanks.
