-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Rear Sway Bar Upside Down?? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/205760-rear-sway-bar-upside-down.html)
RustyWa 02-10-2005 11:36 AM
Can you install the stock rear sway bar physically upside down? I've noticed, on the bar that I have, the portion of the bar that runs from the rear trunk bushings to the droplinks, have a slight arc to them. You can see it in this Pelican photo. I originally had the bar installed so the arc was going the other ways..then noticed this photo so I uninstalled the bar. I'm about ready to put it back in now.
http://www.pelicanparts.com/techarti...y_pic2_big.jpg
Is there a right and wrong way to install this?
SirAndy 02-10-2005 11:39 AM
Re: Rear Sway Bar Upside Down??
Originally posted by RustyWa
Can you install the stock rear sway bar physically upside down? I've noticed, on the bar I have, that the portion of the bar that runs from the rear trunk bushings to the droplinks, have a slight arc to them. You can just see it in this Pelican photo.
Is there a right and wrong way? Can you get a binding problem?
yes, yes and yes.
we actually run it "upside down" on the race-cars. if your car is too low, the stock setup will hit the trunk floor. that's why we switch them around.
works just fine ...
SmileWavy Andy
RustyWa 02-10-2005 11:41 AM
Ok..so if I understand correctly, the photo shows the factory "intended" install, arc "down". If your car is lowered..you could flip it the other way so the top of the arc would be facing "up".
Acox914 02-10-2005 12:31 PM
i have a VERY low car...im installing a rear bar... facing up or facing down?
Acox914 02-10-2005 12:57 PM
EL BUMPO
Dave at Pelican Parts 02-10-2005 12:59 PM
Don't EL BUMPO, please. It wasn't far enough down in the order to warrant one.
The implication is pretty clear--arc UP if you've got a lowered car.
--DD
skline 02-11-2005 10:32 AM
Ouch, that sounded like a slap on the wrist there.
mattr_914 02-11-2005 10:34 AM
If aaron was an admin here, he would have deleted dave's post :D
skline 02-11-2005 10:36 AM
Probably, but since he isnt, lets all enjoy the little chuckle from that one. :)
bd1308 02-11-2005 10:42 AM
LOL
Eric_Shea 02-11-2005 12:10 PM
Whacked by the Wet-One!
