-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   D-Jet help: FI trigger points (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2073-d-jet-help-fi-trigger-points.html)
AlexO 08-26-2000 08:57 AM
My injectors don't fire while cranking. They will fire when I sweep the TPS, so I know that the injectors and grounds are good. I have checked continuity across the points, they seem to be ok. The only strange thing I have found is on the plug that goes to the FI points, there is a 5v signal on on of the side terminals, shouldn't the voltage be on the center one? I can't tell for sure looking at the diagrams....
--Alex
-'74 2.0
AlexO 08-26-2000 10:12 AM
Just checked continuity from the plug to the ECU according to the PP diagram, and its all good.
--Alex
