Is Alternator Hard To Change?
Mine is making bearing noises,Its been in the car for 35 years. Its looks like a bear to get at.....
Take Care,914 |
easy. access is from under car. somewhat basically, but refer to repair manual for complete procedure:
loosen belt remove piece of engine tin disconnect wiring unbolt alt installation is reverse |
Will the alternator from a '75 1.8L fit a '73 2.0L?
Yes, the alternators for the four-cylinder 914s are all the same.
Check the Tech Articles for a slightly more detailed version of how to replace the alternator. http://www.pelicanparts.com/techarticles/914_alt_replace/914_alt_replace.htm No pics, sorry! I didn't have a digital camera at the time. --DD |
a valuable first step is to climb under and spray all those screws on the cooling tin with wd-39 or equivilent a few times over a couple of days prior to tackling the job. Also, get some spare 10 mm ( i think ) machine screws fer the tin. Don't forget about the 10mm bolt reached from over the engine that is between the alt and the fan holding the tin to the engine case.
| All times are GMT -8. The time now is 06:33 PM. |
