JW Apostate
trekkor's Avatar
Question 911 oil combo guage wiring help
I have the guage in the car and the temp side is wired.
It's the pressure and idjit light that I need help with.
New wires are run from the senders to the guage.
What wire goes where?
I have four wires. One off the idiot sender and three off the pressure sender.
Help me help myself.
KT
'74 914-6 2.6 SS #746
'01 Boxster
'73 914
Old 03-02-2005, 09:00 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
one for the oil temp from the temp sender underneath
one from the oil idiot lite side of the sender
one from the oil pressure side of the sender
one for ground IIRC
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 03-02-2005, 05:07 PM
SirAndy's Avatar
Re: 911 oil combo guage wiring help
show me your pressure sender ...
the idiot light is a separate sender. the pressure sender should only have 2 wires max. if it has 2 wires on top, it's a dual sender, one side for the gauge, the other for the idiot light.
in which case one of the 2 idiot light senders would be redundand ...
Andy
>> 1970, 914-6, 3.6L TT4/AX4 - Shall I say... 3.6 (My conversion thread)
>> 1970, 914-6, #374 (Original) For sale!
Old 03-04-2005, 05:16 PM
KT,
Hopefully this will help.
A Oil Pressure gauge
1) Red/White wire to the "+" terminal. This wire also goes to the Gen. idiot light and to the Oil Temp Gauge (I will call it the RW wire) and to some of the other gauges. It is a + 12v supply wire.
2) Green/Red wire to the "G" terminal. This wire comes from your engine sensors.
B Oil Temp Gauge
1) Green with Black bars to the "G" terminal. This wire comes from your engine sensors
2) The RW wire to the "+" terminal
Generator Idiot Light
1) A blue wire to the side terminal. Comes from alternator
2) The RW wire to the center terminal.
Please note that the wattage rating on the generator idiot light is important. I think it is a 4 watt bulb but check your manual. (Larger then some of the other bulbs) If you don't use the proper wattage bulb, the bulb will remain lite all the time.
Brake Light
1) A Black/White/Green wire to one of the terminals.
2) Two brown wires with yellow stripes to the second terminal.
Instrument Lighting bulb
Black/Blue wire which also goes to other gauges This is a variable voltage wire tied into the light dimmer reostat on your headlight switch.
Grounding
A plain brown ground wire goes to three grounding lugs on the back of the sheet metal housing and also goes to other gauges.
Good luck with your wiring job. Lyle
Old 03-05-2005, 07:16 AM
JW Apostate
trekkor's Avatar
Here's the senders. The wiring is new, goes through a loom, into the tunnel and comes out behind the guage.
Thanks for your help, KT
'01 Boxster
'73 914
Old 03-07-2005, 07:38 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
That is someone's hacked-up mess, there. Throw it away and get the correct senders, Trekkor. There should be two senders, each of which only has one wire, and they live in different locations on the engine. I believe the pressure sender for the gauge is toward the front (fan end) of the engine, while the light sender is toward the back (flywheel end) of the engine.
--DD
Old 03-07-2005, 09:24 AM
SirAndy's Avatar
i agree with the damp one ...
Andy
Old 03-07-2005, 02:36 PM
The one by the fan is Temp.
Pressure and idiot light sender flywheel end. On an early six that is.
Old 03-07-2005, 02:42 PM
