Turn the key... Engine revs to redline
I have the car all back together now and I'm hoping I simply screwed something up with the throttle linkage. As soon as I start the car the tach flies up to the redline before I turn it off. I had the engine removed from the car so the cable was disconnected. How do I adjust the cable?
'73.5 911T
'87 944S
'78 928
Old 03-08-2005, 06:07 PM
elwood-914's Avatar
Throttle return spring?
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 03-08-2005, 08:04 PM
I saw your post about it breaking, mine is on there, could I have put it on wrong? I thought there was only one way for it to go on.
'73.5 911T
'87 944S
'78 928
Old 03-08-2005, 10:03 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
I had this problem when I messed with my carb, it ended up being the throttle return spring...i forgot to put it back on
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 03-09-2005, 12:40 AM
elwood-914's Avatar
Do you have stock F.I. or carbs? What is the position of the butterfly flap in the throttle body? The return spring should NOT pull it into the open position. Good luck
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 03-09-2005, 05:20 AM
914 Geek
First, check the throttle valve. Is it all the way closed?
Next, check your vacuum hoses. If you still have D-jet, the idle will be very high (could even be redline!) if enough hoses are unplugged.
--DD
Old 03-09-2005, 08:34 AM
norustscott's Avatar
I vote for Vacuum leak too. It will soar with a manifold vacuum hose off...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 03-09-2005, 08:39 AM
914fan's Avatar
2 things to check.
1 Put the car in nutral and start the car without the clutch. I had a problem where I pressed the clutch and it caught the throttle cable.
2 If you have a hose connected to the fan shroud it should be going to the fuel tank vapor system. NOT THE INTAKE AIR DISTRIBUTOR. ask how I know.......
beyond that check the obvious. It is always the simple stuf that gets screwed up.
Old 03-10-2005, 01:55 PM
Thanks for all of the ideas. It's not the return spring. I don't think it is vacuum because everything looks right but I won't rule it out. I was only starting it with the clutch pedal in, so I will hope that it is catching on the throttle cable. The butterfly is closed when the car is off also. I'll let you know what I find out. Thanks
'73.5 911T
'87 944S
'78 928
Old 03-10-2005, 06:52 PM
did you replace any cables? make sure there's no interference with the clutch and throttle cables in the center tunnel.
k
here? not so much i think. high five!!!
Old 03-13-2005, 07:43 AM
