complete engine rebuild
So I'm planning a complete engine rebuild, 1.7liter to a 2.058.
So here is my list so far, what am I forgetting??
1.8 heads that Len Hoffman is redoing for me
96mm pistons from Aircooled.net (although I have no if as to if they are dished, flat, or domed). Have found a 71mm crank
71mm used crank and rods
complete gasket/seal kit
new main bearings
new connecting rod bearings
new wrist pins,
New bigger oil pump
new camshaft bearings
new cam (not sure which one yet
New twin weber 44 IDF and throttle linkage
Oil pressure booster pistons
New fuel pump for carbs
Jake's video on how to rebuild an enigne, and probably alot of tim and mountain dew.
anything I'm forgeting?
Old 03-10-2005, 11:16 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
tools and 2nd job?
machine shop address?
powdercoaters address?
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-10-2005, 11:30 AM
Send a message via AIM to mattr_914
The final displacement is 2056 cc. I just did the rebuild on the same engine.
If you go with pistons from aircooled.net you'll probably get the KB hypereutectic pistons which are flat top and come with wrist pins.
I would suggest going with a Jake Raby cam. If you're ordering his video you know about his website and stuff. I went with his split duration cam, the aggressive one. I havent fired my engine up yet though, so i cant tell you the results.
You're going to want to get a good oil pump. There are two routes. One, you go with a type 1 oil pump and get a modified cam gear. Two, you get a more expensive special type 4 oil pump. Since you're going to be getting a new cam gear with your cam, I'd go with a type 1 pump. All that stuff is available from jake also.
For linkage I would highly reccomend www.cbperformance.com 's linkage.
You also need a gasket kit. Pelican has a good one, and so does aircooled.net.
That list looks pretty complete. I cant think of anything else. Good luck!
'73 914-4 with 2056
'67 912 with wet paint (SOLD)
'96 GTI VR6
Old 03-10-2005, 11:35 AM
