-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Lowering the rear end (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/212920-lowering-rear-end.html)
mikey 03-25-2005 04:14 PM
How is this done?? Do you need to get shorter struts, or spring clamps?
Thanks,
Mike
Jim Chambers 03-25-2005 07:24 PM
Installing stronger springs (140, 180 etc) lowers the car some as they are shorter to start with. Koni shocks have adjustable spring perches with 3 different heights. Or you can go all the way to threaded collars for the springs which allow more adjustment.
Tidybuoy 03-25-2005 07:27 PM
I believe that it's done with the type of springs. If you go the the Pelican website & look at there springs for sale, it says that the 140, 165 & 180lbs. springs will lower the car about an inch.
I also have 205/50 tires (but I'm going to be switching to 60's in the near future.
Attached is a photo of my car which has 140lb springs (unfortunatey, the photo does not have the car on level ground but it definately sits lower than stock):
http://forums.pelicanparts.com/uploa...1111807562.jpg
Tidybuoy 03-25-2005 07:29 PM
Thanks Jim....I have koni's on the rear of my car and I've noticed that it looks like you can change the position of the spring perch - I've always wondered it that is what that's for.....................Vern
peter carroll 03-26-2005 07:20 PM
I have Koni's on my project car, and noticed if I drop the circlip to its lowest position, the spring "slops" around when the wheels are off the ground. I guess one has to be careful that they are in correct position when lowering the car to the ground. Good Luck
scotty914 03-26-2005 09:49 PM
hello pete, are you going to be in baltimore any day in the next 2 weeks, i was wonder if you want a ride the suby powered 914. it is very quik !!!
914fan 03-28-2005 08:14 PM
Just leve the 30+yr ols springs in there. Thats how I lowered mine. Mi car only has 1/2 to 3/4 inch space between the rim edge and the fender lip. Looks great even if the car dosent. My wife calls it rusty the rust bucket. I just grin and drive. frame is great its just surface rust.
jkeyzer 03-29-2005 12:01 AM
Get some $100 ea. Bilsteins with the adjustable spring perch and maybe some Weltmeister 100 (or is it 110?) or 140lb springs.
