Oil Temperature Gauge
Does anyone know of an aftermarket oil temperature gauge that works with the factory sending unit?
Old 09-15-2000, 07:46 PM
Jim Smolka's Avatar
I know that VDO makes gages that will work. However, the new VDO gages are smaller.
Q. Why not use the stock gage and the stock sender???
Old 09-15-2000, 08:17 PM
I built the car for vintage racing. I took the multigauge and speedo out. I rebuilt the dash is aluminum and only used the original tach. I put in mechanical oil pressure gauge, oil pressure warning light, etc. I have not put in a oil temp gauge yet and have been concerned about oil temp. I run a Mazda RX7 oil cooler, so it should not be a problem, but why take a chance. If a VDO gauge will work, that would be good. Thanks.
Old 09-16-2000, 06:54 AM
mejulihn's Avatar
VDO makes a very nice gauge set called their "Cockpit Series" with black face, white numbers and red pointer that complements the stock Porsche gauges very nicely. Combine the oil temp gauge with a matching sending unit that is a direct replacement of your stock sender in the bottom of the case, and you will be good to go.
Old 09-16-2000, 10:21 AM
also, there is a sending unit for the VDO oil temp gauge that replaces the drain plug. i got one from california imports (i think the web site is www.vwcalimports.com). pelican parts can probably get any thing cal imports can.
Old 09-16-2000, 02:04 PM
I bought the VDO Cockpit style 300 deg F temp gauge and also bought a VDO 300 deg F sender to fit the stock oil temp threads (M14x1.5) The VDO # for the sending unit is 323 055 I bought mine thru racesearch.com they have a lot to offer and have very good prices.
Old 09-23-2000, 05:05 PM
RETIRED
Joe Bob's Avatar
They made more than a few VDO gauges for VW and Porsche applications....you would be well served to get a matching sender and gauge....they made a lot in different temps and ratings....I would definitely NOT try to use a gauge with an unknown sender....
Old 09-23-2000, 06:06 PM
