TFI TFI is offline
10 yrs already??
front valance panel removal
i would like to put a front spoiler on my car, but can't seem to get the front valence pan off. i found the two screws on the ends, but can't seem to find any more.
what steps am i missing for getting it off?
TIA
Old 10-04-2000, 07:02 AM
Send a message via AIM to JP Noonan
Pretty sure the bumper has to come off, or see if you can squeeze a wrench between the bumper and the valance. I think there are 4 or so bolts across the top of the valance along the bottom edge of the bumper.
If it is a 70-74 there are two nuts inside each fender under the turn signals to remove the bumper. If it os a 75-76 there are two large bolts (17mm I think) that are removed throught the two holes under the bumper behind the "bumperettes" or "nipples". Remove the two large bolts and wiggle the bumper off the shock absorbers, but leave the shocks attached to the car.
[This message has been edited by JP Noonan (edited 10-04-2000).]
Old 10-04-2000, 07:28 AM
racejoe's Avatar
Yes, the bumper has to come off first.
Old 10-04-2000, 11:15 AM
i have a special edition front spoiler on my car. i had to do something to it and had to take the front bumper off. on a 74, there are only 4 nuts & bolts holding the bumper on so it's not too difficult.
Old 10-07-2000, 04:19 PM
I removed the stock front valence on my 1974 without a problem...you don't have to remove the bumper. Remove the two small bolts on the ends (accessed through the front wheel wells); then remove three or four more screws from inside the front trunk. The screws are 8-mm jobs that are pretty close to the edge of the trunk floor. You have to remove the spare to get to them.
Old 10-08-2000, 08:32 AM
