clock options
I would like to fill the center console hole were the original clock, which no longers works with another clock. Any drop in options out there? Greg
do a search, there's a thread somwhere on how to fix the clocks, they are the same as beetle clocks and they all break, but as I recall, the fix is easy... easier than finding a replacement
indeed an easy fix if it is the style of clock with the white plastic backing. I just did it myself using the pelican tech article. Steve
Make a new gauage panel and install a 911 clock, and a dual 911 gauge.
Looks really sharp and you can see it easily. CCLhttp://forums.pelicanparts.com/uploa...1114662802.jpg |
or, just buy a watch ;)
or use the clock on any modern radio, and put a CHT in place of the clock |
| All times are GMT -8. The time now is 08:52 PM. |
