Clutch Cable Pulley Bracket
The bracket that holds the clutch cable pulley on my '74 is bent. I checked Pelican's site and only found the pulley:
914-423-255-02 Anybody have any idea where I could source a new bracket or if I should just try and bend it back? -Aaron
Aaron McKinnon '74 2.0L 914 '66 Drag Bug -SOLD- |
I think the stamped piece is just mild steel and could be straightened out. I would remove it first since the tranny is not strong enough to handle that kind of shock where the bracket is bolted on. Good luck
