Wes Wes is offline
901 Transmission
After reviewing all of the bulletins posted on transmissions ailments, I still need HELP. My 75 914 side shifter fails to function at all in 5th gear. All other gears work fine and shifting is good as I have replaced the bushings. There is no grinding when I try to shift into 5th, there is just nothing. I have removed the linkage and tried to shift into 5th from under the car. It felt as if it went into gear, but upon appling a little pressure via the wheel it popped out. Is there a fix other than rebuild?
Old 07-09-1998, 07:10 PM
Wes, this happenned with my 1974 914 a couple of years ago, and the cause was that the teeth on fifth gear were worn off. You will likely need to replace fifth gear, and this will require disassembly.
Old 07-11-1998, 09:06 PM
