-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 control board (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/227-914-control-board.html)
Bryan Wilson 07-12-1998 04:56 PM
914 control board
My 914/6 control board (the one holding the alt. voltage regulator and other relays), which is the same as a 4 (I guess) has a tar coating on the underside. Over the years the tar has cracked and I've decided to remove the rest. Question now is, do I recoat it with roofing tar or epoxy or is there some other better way. I'd like to hear from anyone who has faced this issue.
Bryan Wilson/914/6
Wayne 962 07-12-1998 10:36 PM
I would coat it with a thick clear epoxy, so that you can see if there is anything going on inside the board. Just make sure that it's non-conductive.
The 914-6 and 914-4 have different relay boards, as far as I can remember...
Hope this helps,
Wayne
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
