Engine pic of components
I once saw a pic in a post that had all the electrical sensors and FI components labeled. I cannot find it now. anyone have that pic? I'm trying to locate the CHT sensor and cold start valve.
Mike |
I don't have pics gut the cold start valve is usually installed in the intake manifold - that's the center piece, not the manifold pipes. The CHT sensor is screwed to the head on the passenger side of the car near the rear spark plug. This is going to just be a wire going thru a small hole in the engine tin.
What size engine? I believe that there are slight variances between the 2.0 & 1.8. Vern |
'76 2.0 d-jet. Hey you are the guy with all those 914s in Fresno. I see your auctions on ebay all the time.
Mike |
try this link: http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/226494-fuel-vacuum-hose-diagram-73-914-4-2-0l.html
3rd or 4th post down CHT sensor is not on it. |
I only have 4 914's and one of them is my baby. Two have been completely parted out and I'm just starting on the last one. When this is all over......I'm taking a long break.
Yeah, that's me.... |
Sorry I didn't label the CHT but it is next to #3 cylinder or bottom right in this pic.
Geoffhttp://forums.pelicanparts.com/uploa...1119294369.jpg |
Thanks so much Geoff and Conrad.
| All times are GMT -8. The time now is 08:57 AM. |
