bd1308's Avatar
Send a message via AIM to bd1308
cleaning out dizzy, sprayed my eye with carb cleaner
ouch...it hurt for a long time....
my eye is still red.
the problem didnt go away so i'm going to grab my other FI dizzy and try that tomorrow morning...
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 08-23-2005, 08:07 PM
jsteele22's Avatar
Well, like they say with lasers : "Never look into the beam with your remaining good eye..."
Old 08-24-2005, 10:01 AM
Britt,
make sure that you re lubricate everything in that dizzy or you will have problems later.
I made that mistake once of cleaning it with carb cleaner...
after that the car kept dying suddenly and leaving me.
found that I forgot to relubricate the points blocks and lost the point gap in a couple hundred miles.
don't re-use that dizzy without fully re-lubricating the shaft and the points (with distributor points conductive grease)
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-24-2005, 10:17 AM
bd1308's Avatar
did that, thanks for the tip.
I too forgot about the distributor grease the first time and I got stranded on a major interstate...
i oiled everything with 10W-30 oil, and put some in the shaft too...
Old 08-24-2005, 12:00 PM
