' 73 2.0 fuel pump question
Will a ' 73 2.0 fuel pump work in a ' 75 1.8 ? Thanks
Old 07-06-2005, 01:35 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
yes and no
it can be made to work, however since the 75's fuel pump is in the front of the car, you'll have to change that, also the connections are different.
Essentially you'd be backdating to an earlier pump... You'd have to figure out how to re-route the fuel lines to the pump..
The 75 pump has two, the 73 pump has three
Old 07-06-2005, 01:48 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
In addition, the 75 pump has a larger inlet fitting than the earlier pump does. You can fit the early pump up front and deal with the extra port on it, but you'll have to do some "adaptor magic" to get the fuel hose sizes to work out correctly.
--DD
Old 07-06-2005, 02:15 PM
