gliderguy's Avatar
Another temp question with pic
Hello there 76 911s 11 blade fan, no external oil cooler. No thermal reactors. 80 degrees outside 40 minute drive . Is this temp reasonable. It is my 1 year anniversary, taking the wife to Niagara Falls on Saturday {3 hour drive} Wanted to make sure car would be ok. Any help would be appreciated. I have been hunting down a Idle problem, which is fixed, thanks to everybody here!!!!! I had a crack in my airflow sensor boot and I disconnected my decel valve.
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa
01 Suburban
02 Jeep Liberty
WillsWings Eagle
"As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 "
Old 07-21-2005, 08:14 PM
gliderguy's Avatar
Bump
no Replies?
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-21-2005, 08:21 PM
gliderguy's Avatar
I even put a picture in
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-21-2005, 08:29 PM
914 Geek
Is the sensor/gauge accurate? If so, 235 is a bit high. 240F is usually considered "too hot" in the 911 engines, while 250F is "too d*mn hot" (a la Anderson).
You might have more answers on the 911 board; most of us here on the 914 board see 76 911s as parts donors...
--DD
Old 07-21-2005, 10:16 PM
gliderguy's Avatar
wrong forum sorry!!
posted to the wrong board
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-21-2005, 10:24 PM
