Fuel pump %3£!!!! and FIB
How can you know if your fuel pump run???
I disconnect the pump and try direcly with the batterie, I had only small bounce!!!
How can you know if your FIB work?
Thanks to everyone
Old 12-02-2000, 07:20 PM
Send a message via AIM to JP Noonan
Fuel pumps make a whine as they run, it is loud enough to hear with the engine off, while sitting in the car. If it dosn't run check not only if it is getting +12 volts but that the ground is good. If it runs use a fuel pressure gauge and make sure the fuel injector rail is getting 28-30 psi. Also make sure the battery is good.
What is a "FIB"?
Old 12-02-2000, 09:20 PM
Could it be "Fuel Injection Brain"?
Matt
Old 12-03-2000, 08:22 AM
