Thack's Avatar
Send a message via Yahoo to Thack
Distributor retard
Why does the 914 need distributor retard? When the static timing is read without the hose on a '76 2.0 d-jet, what should it be roughly? Is it around 7-1/2 BTDC then it is retarded to 0 BTDC? How far can you advance the timing before trouble starts?
Mike
Old 07-19-2005, 03:30 PM
BURN-BROS's Avatar
I would expect the vac retard to be strictly an emissions factor for idle and off idle. I would not advance the distributor if maximum advance is o.k. or the rate of advance is steep. Map your advance in 1000 rpm increments with a timing light to get an idea where you are at.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-20-2005, 07:13 AM
Thack's Avatar
So can I disconnect the retard hose if if runs better?
Mike
Old 07-21-2005, 07:40 AM
BURN-BROS's Avatar
Try it and see. Be sure it doesn't ping.
Burnham Performance
Old 07-21-2005, 09:09 AM
