djs djs is offline
Cam advice sought...
I'm preparing to rebuild a 2.0 motor for my 914. In researching cams, I checked with Web-Cam. I emailed them with some questions about the relative performance of their mild performance Type 4 cam (00-472) relative to their "stock" Type 4 replacement cam.
Laurie from Web-Cam told me that the stock cam makes power from 0 rpms to about 4500, while the 00-472 grind makes its power from 2000 - 5500 rpm.
Questions:
Does this mean that I would have a motor with virtually no low-end compared to stock? And does it mean that I would need to rev higher to make peak power? (I assume so)
Finally, has anyone else run this cam? It is advertised as a good performance alternative for stock FI with mechanical lifters, which is what I intend to go with. However, I don't want general driveablility to suffer. I am planning to run the European 8:1 pistons, as well.
Any advice would be appreciated!
Thanks,
Dan Schmitz
Old 12-01-2000, 12:45 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
I like the Norris 352S grind lots of bottom end. It is a dual grind, one lift and duration for intake Another for exhaust.It give more mpg too.Steve
Old 12-04-2000, 09:59 AM
djs djs is offline
Steve,
How can I get more info about this? Is Norris a cam grinder?
Thanks,
Dan
Old 12-04-2000, 10:02 AM
Banned
You can call them at 818 780 1102.Steve
Old 12-04-2000, 12:54 PM
