-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Another temp question with pic (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/232308-another-temp-question-pic.html)
gliderguy 07-21-2005 08:14 PM
Hello there 76 911s 11 blade fan, no external oil cooler. No thermal reactors. 80 degrees outside 40 minute drive . Is this temp reasonable. It is my 1 year anniversary, taking the wife to Niagara Falls on Saturday {3 hour drive} Wanted to make sure car would be ok. Any help would be appreciated. I have been hunting down a Idle problem, which is fixed, thanks to everybody here!!!!! I had a crack in my airflow sensor boot and I disconnected my decel valve. http://forums.pelicanparts.com/uploa...1122002050.jpg
gliderguy 07-21-2005 08:21 PM
Bump
no Replies?
gliderguy 07-21-2005 08:29 PM
I even put a picture in
Dave at Pelican Parts 07-21-2005 10:16 PM
Is the sensor/gauge accurate? If so, 235 is a bit high. 240F is usually considered "too hot" in the 911 engines, while 250F is "too d*mn hot" (a la Anderson).
You might have more answers on the 911 board; most of us here on the 914 board see 76 911s as parts donors... ;)
--DD
gliderguy 07-21-2005 10:24 PM
wrong forum sorry!!
posted to the wrong board
