degreeoff1's Avatar
901 tranny and this ?? ZF limited slip?
Looking at this on ebay and wonder if it will fit my 914?
Very rare early Porsche ZF 901 limited slip differential for '64-'68 aluminum case transmission. Good shape but I have no idea what "slip" it's set at. Comes with matching axle flanges.
The only markings/numbers on the diff are:
4061 004 0041 435 848
Josh
Old 08-05-2005, 07:42 AM
Tidybuoy's Avatar
I'm fairly certain that you can convert your existing trans to limited slip with the parts from this transmission but, I don't think you can just use the transmission as-is. Since this is '64-'68 I'm assuming it was out of a 911. The problem is that the engine & trans in a 914 are in backwards and so if you just install this as-is you will have 5 reverse gears and 1 forward.
I'm not an expert but someone else here can chime in on this..................Vern
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 08-05-2005, 08:37 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I haven't heard of an aluminum-case 901; I had assumed they were all magnesium like ours. However, our transmisison is a version of the 901 gearbox, so the ZF clutch-type limited slip for a 901 "should" work in a 914 gearbox.
I am not certain, though.
--DD
Old 08-05-2005, 09:33 AM
Acox914's Avatar
Send a message via AIM to Acox914
--DD
Dave -
i have in my possession a 4 spd aluminum 901. weighs way more than a loaded Mg case 914 box.....
AA
-Aaron
"60% of the time, it works every time"
Old 08-05-2005, 09:50 AM
This LSD has the output for the old "universal Joint" coupling not the CV joint coupling. The LSD MIGHT work but you would have to get replacment output pieces. Gaurd Transmission may have them.
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 08-08-2005, 07:52 AM
The early 901 ('65-'68) diff uses diff bearings with 45mm ID. The late 901 & 914 diff uses bearings with 50mm ID. This is one of the major areas where these two diffs "differ".
Old 08-10-2005, 07:45 AM
