-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Fuel tank question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/236918-fuel-tank-question.html)
peter carroll 08-19-2005 08:38 PM
Fuel tank question
I removed both of the metal pipes at the bottom of the gas tank to clean the tank. The smaller diam. pipe needs to be blocked due to my engine conversion. Everything was so nasty, I couldn't tell what type of washer or whatever is needed to keep them leak proof. Also, Is there a threaded cap out there that can be used to totally seal one of the openings off? Thanks
mr-dwight 08-22-2005 11:53 PM
you may be able to find a copper pipe fitting that you can sweat on.
Will98D 08-23-2005 01:34 PM
or crimp the tube/fitting you removed, braze it shut and reinstall it.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
