djs djs is offline
Source for 10mm swivel tappets...
Does anyone know of a source for 10mm swivel valve tappets? I can find the 8mm variety everywhere, but haven't come across the 10mm size, which is common to 2.0 Type IVs.
Again, thanks in advance!
Dan
Old 12-22-2000, 03:32 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Just switch to early type rocker arms that use the smaller tappet. Get them at a junkyard for cheap. Also, grab the solid spacers off a hyd.valve bus motor to get rid of the springs that space the rockers. You will have to grind some of the arm off to get the "feet" to fit or cut off some of the pushrods.
Geoff
Old 12-22-2000, 05:08 PM
