AIR (SMOG) PUMP DRIVE
AIR PUMP DRIVE BRACKET/PULLEY ASSY NEEDED FOR 2.0 ENGINE. OR DOES ANYONE KNOW HOW TO REPLACE/REPAIR THE BROKEN RUBBER COUPLING.
I've used 3M super weatherstriping adhesive on sheared off motor mounts. I don't know how long it will work for though. Try a VW dealer I beleive the later busses had the same tripod/rubber mounting thingy as the 914. BTW if you find one please let me know. I need the part that goes between the rubber coupling and engine for my 912E.
