h16 h16 is offline
h16's Avatar
brake proportioning options
I'm considering replacing/removing brake proportioning valve. I currently have stock calipers which I recently rebuilt (thanks to Pelican for tech article on rear caliper). It still feels spongy to me, although I can stop pretty effectively & reliably. I did try lot's of bleeding with pressure bleeder, and I did loosen both fittings at proportioning valve (to bleed) when under pressure.
I've read that some have replaced proportioning valve with a mere junction block. Does anyone have experience or recommendations on options such as this?
I'm also about to put bmw 320 calipers up front. I would expect this to change the proportioning requirements. Any known "adjustable" proportioning valves out there that are recommended?
'74 1.8
Old 09-15-2005, 02:11 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
it's common to replace the valve with a "T" purchased for about $5 at the local VW shop....
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 09-15-2005, 03:29 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If you still have stock brakes, I would not recommend replacing the proportioning valve with a "T". Locking up the rears before the fronts is a good way to get the car to swap ends. There are a few people who have not had difficulties with the T and stock brakes, but I think those are the exception rather than the rule.
If you put calipers with larger pistons up front, you change the front-to-rear bias toward the front. You can then reduce the pressure-limiting effect of the proportioning valve (theoretically the stocker is adjustable; or you can go aftermarket) to move the balance toward the rear, leaving it in more or less the same place where it was.
Some people go to a 'T' when they put the 320 calipers on the front, but the good folks at Grassroots Motorsports magazine (http://www.grassrootsmotorsports.com) found that they still needed a little bit of rear pressure limiting action even with that setup.
Tilton makes an excellent proportioning valve; one which does not introduce any sponginess or springiness into the pedal feel. I don't know who makes the one we sell, but I am confident that it is a quality piece as well. You will have to make brake line adaptors to plumb either one into the system, though! I know someone was selling a complete setup (valve, T, adaptor lines, all together) but I don't remember who it was.
I hope this helps.
--DD
Old 09-15-2005, 08:04 AM
Tidybuoy's Avatar
I have the 320i setup and I left the stock proportioning valve alone. Everything works great.
Vern
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 09-15-2005, 09:12 AM
