-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Pressure Sensor Mounting (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2421-pressure-sensor-mounting.html)
surfcity914 01-04-2001 01:06 PM
How does the manifold pressure sensor bracket attach to the car? There is a threaded hole for the top bolt, but how do the other 2 holes on the bottom of the bracket mount, and with what screws?
jmcleod 01-05-2001 05:29 AM
if i remember correctly, the bottom 2 holes are phillips head machine screws, probably 6 or 8 mm. the bracket is attached to the passenger side of the engine compartment and the top screw/bolt also mounts the decel valve. the bottom screws/bolts are kinda hard to get to but not impossible hard.
