bd1308's Avatar
Send a message via AIM to bd1308
So....heating is next on the list
Hi All!
What is the best way to go about R&Ring my heating tubes and flapper boxes?
Should I get them acid dipped and powercoated, or what would the peanut gallery recommend?
b
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 10-18-2005, 06:17 PM
Probably bead blasting is better. I think acid is too corrosive and can damage metal parts. Powdercoating might work OK but could cause problems with the moving parts. Just a good quality high-temp paint is fine. Eastwood company sells some good stuff but the FLAPS stuff is probably fine also.
Old 10-18-2005, 08:05 PM
Acox914's Avatar
Send a message via AIM to Acox914
i used slits beadblaster and cleaned them up real well for grimstead.
-Aaron
"60% of the time, it works every time"
Old 10-18-2005, 08:52 PM
bd1308's Avatar
thanks guys...
i'll see if i can't find a beadblasting place in BG....or maybe i'll just sand the paint off and reapply it....
regardless, I think I have all of the pieces.....
thank you for your help....
b
Old 10-18-2005, 09:23 PM
